Good source for new or rebuilt carbs?
fastpakr
2,832
Roanoke, VA
Or a mustang Mach E
You know what the only real problem I have with the Mustang Mach E is?
That they're calling a 4 door car a Mustang. What review board approved this nonsense?
85_Ranger4x4
17,835
SW Iowa
I wont lie. I did seriously consider EFI on it just "for fun" persay. Till i seen the prices. Athough i did find a complete, used, holley 2bbl tbi "projection" set on ebay for 200 bucks. But ive never had issues with running a carb and this truck is just going to be a sometimes driver/work truck and the expense of EFI isnt worth it....espicially with as well as a good 2150 will work in the cold.
However when i get my LTD back out and start working on it i think i might seriously consider jumping ship....just for shits and giggles.
They are out of stock everywhere right now but reman snipers are listed for $800. FiTech is about in that area too.
I poked around at running a GM TBI, it seems by the time you get all the parts and either a chip or mega/micro squirt it you are at about the same price as a sealed self learning kit.
Probably the same ones that thought it should be called a Mach 1 when they announced it in Detroit. I bet they got a lot of fan mail over that...
fastpakr
2,832
Roanoke, VA
At least when they unveiled the idea in Detroit they were still pretending it was a normal Mustang body. You can make an electric Mustang fast, so why not use the Mach 1 badging if it's got the goods underneath? I realize it's going to be hard to muscle it around a track as well as a gasser because of the added weight, but straight line acceleration could be solid.
85_Ranger4x4
17,835
SW Iowa
It wasn't going to be Mustang, just Mach 1 was my understanding.
Mach 1 probably should be left to the regular Mustangs for the time being along with Boss 302 and Bullitt IMO. Mach E would have been very fitting paying homage to history and the future at the same time... if it was actually anything like a Mustang.
fastpakr
2,832
Roanoke, VA
You might be right about that - I don't remember it that clearly.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Still alot of money. When i can buy a edelbrock carb and intake for just over half that.
I dont know....it might happen on my LTD. Probably not on my 77 F250.
Digging into the issues i had with rusty kinda made me a bit more interested to learn more about how EFI works even if EEC IV is a primitive 35 yr old system.
It was a massive headache....but kinda fun at the same time.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
When I am already more than doubling the hp what is another 5hp? My research at the time turned up that the Edelbrock was better offroad and at holding a tune than a standard Holley, and basically has a tub to hold the fuel with no gaskets to leak fuel. Rusty nailed it, I wanted a daily driver type setup with good torque as I will never race it. Since then I have done way more with the truck than I ever thought I would and it just takes it in stride.
IIRC the stock 4bbl for a 5.0HO is around 480cfm (starting out mine was a "standard" roller engine" I don't think Holley makes a 4bbl close to that aside from the 470cfm truck avenger. Most are around 600 which IMO is huge for a stockish engine especially the 150hp weezer I started out with. With the 500cfm Edelbrock that I have it is set down a little, even now with an HO cam and E7 heads it has plenty of capacity to throw more fuel if needed.
Everything I do with the truck, it toys with it. Shuttle wagons around, hauling around my slide in camper, drive heavily loaded across four states... the old half wore out 302 doesn't care.
If I wanted peak power... I wouldn't be dinking with a carb period. I am not opposed to a Holley... but if I get one it will be a Sniper.
I used a Holley 600 cfm on the mild 302 I stuck in my 81 Cougar and it liked it fine, at first I had a 390 cfm on it but it had better throttle response with the 600 and the gas mileage didn't change. The 2 barrel on a lot of 302's flowed about 300 cfm just like the primaries on a 600 Holley. Ford used to put 480 cfm Autolite 4100's on 390's and a 428 SCJ only got 715 cfm, both responded well to bigger carbs.
