For a 2008 Ranger with V6~4.0L~SOHC Engine + 5r55e Tranny + 1354 TransferCase + ....
at 150kMiles, if Engine is removed+rebuilt, might as well rebuild the Tranny too; a judgement call only you can make.
Ok if NOT rebuilding Engine+Tranny, starting at front of vehicle,
personal recomendations for a "100kMile maintenance routine" with a few reliability upgrades, subject to debate+change:
~ Add a 2nd left stock TransCooler, parallel to 1st right TransCooler at right, new Hydraulic ATF Hoses+DoubleWormClamps+StainlessBarbTees
~ Replace junk PlasticTanked 2RowCore Radiator (NotoriousFailureItem) with AllAluminum 3or4RowCore Radiator
~ New 16psi RadiatorCap, MotorCraft\Stant preferred
~ New 1.5"ID RadiatorHoses + DoubleWormClamps, consider StainlessFlex instead of Rubber, easy & slightly increases cooling capacity
~ New Fan+Clutch+WaterPump, MotorCraft preferred
~ Replace junk Plastic ThermoStatHousing (NotoriousFailureItem) with Aluminum version; DONE !
~ Replace junk Plastic 2wayHeaterBallValve (NotoriousFailureItem) with OldStyle Metal 2wayHeaterPlugValve; not applicable to 4WayValve.
~ New CoolantHoses + DoubleWormClamps, reverse HeaterCore hoses at FireWall
~ New Coolant, Gold\Yellow Non2EHA MotorCraft# vc-7dil or Peak# pkpb53 or Zerex#zxg05ru1 preferred
~ New SerpBelt, Continental#Elite or GoodYear#GatorBack preferred
~ New BeltTensioner+IdlerPulley, or at least take them apart, clean+lube
~ Remove OilPan, remove+clean OilPumpScreen, inspect for broken TimingGuides, new FumotoDrainValve, new OilPanGasket.
~ New OilPresurized TimingTensioners (NotoriousFailureItem), MotorCraft\Cloyes preferred, no cheap\lesser offbrands
~ New Oil+Filter; 0w30.FullSyn & K&N#HP Series preferred
~ New AirFilter, "Performance" ColdAirIntake is waste of good money+time
~ Inspect+Clean AirIntake MAFSensor, Inspect+DoubleInsulate WiringHarness
~ Remove+Clean+Lube ThrottleBody, reinstall with lite smear of RTV on Gasket\ORing
~ Inspect+DoubleInsulate ThrottlePositionSensor WiringHarness if Equipped
~ New VacHoses + LiteSpringClamps
~ New PCVValve; replace PCVHoseElbows (NotoriousFailureItem) with tougher 5/8"ID HeaterHoseElbows
~ Remove+Clean+Lube+Test IdleAirControl\IACValve, reinstall with lite smear of RTV on Gasket.
~ New Plugs, MotorCraft\AutoLite Platinum or Iridium preferred, "Performance" OffBrands likely waste of money+time
~ New Wires, MotorCraft\Equal preferred, "Performance" OffBrands likely waste of money+time
~ Remove+Clean+Test CoilPack, renew if needed; MotorCraft preferred, "Performance" OffBrands likely waste of money+time
~ New OxSensors 3places, MotorCraft\Bosch only, Bosch# 15719 with 24inLongCable+FordPlug will replace all Ford 4WireNarrowBand OxSensors
~ New FuelFilter, fill Tank with PremiumGas + bottle of InjectorCleaner once\twice a year
OutOfTime, GottaGo, to be continued...
