Gauge cluster conversion.
NPdarkside21
ASE Certified Tech
3.0L
235/75/R15
Work Smarter not Harder
So my '99 XLT does not have a tachometer/RPM gauge, can I get a gauge cluster with it, from another ranger that actually has it, and just rig up a way to get it to work? Or will this just screw things up?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Any 1998-2003 cluster will fit fine without issue. How to wire in the tach I have no idea. It's probably already wired for it though and would just be a plug and play situation (I know you need to set it for 4 or 6 cylinder with a grounding plug on the back) but someone else would need to verify that.
You cannot use anything from an 2004+ truck, they look similar but are computer controlled.
8,372
Yes, your 1999 will have the tach wire in the cluster wiring so you just need a cluster that has a tachometer
It can be from a 4cyl or V6 Ranger, if its from a V6 Ranger(3.0l or 4.0l) you don't need to do anything it will just work
If its from a 4cyl then you will need to change a ground wire on the cluster
Get the cluster first then if needed you can find out which ground wire to change
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Having Ron verify your questionable answers always gives you a warm fuzzy feeling. :icon_rofl:
