Gas in my oil… still
trinogt
5
central Florida
Mazda
2.5
Running at idle, I get 32 psi fuel pressure. After shut down, it maintains 32 psi for about 30 minutes, but in an hour it drops to 20 psi… not sure if that’s normal or not. Dipstick looks like clean oil. Here’s a photo of sample as taken from oil pan.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Have you tried to use a stethoscope to listen to the injectors after shut down. Might hear one bleed down. Only three places for pressure to go, FPR, injectors<<, HP fuel pump
svtcards
137
Lyman maine
302
3'' front 4''back
If it were coolant... you could see it.
He said it smells like fuel.
I still think fuel pressure is the first thing you check. Usually a leaky/stuck open injector can be seen by the falling fuel pressure when you shut it off.
I was told losing all fuel pressure over night isn't an uncommon thing
trinogt
5
central Florida
Mazda
2.5
I listened to the injectors while running, and listened to intermittent valve clatter, but I don’t know how long I’d be able to keep a stethoscope on any injector if it takes over an hour to bleed down? I still can’t rule out coolant- the smell could just be excessive hydrocarbons… I was hoping to see stratification in my oil sample, honestly lol. I’ll be running a compression test tomorrow on all six… I also think I need a new fan and clutch- I can stop the fan turning easily while hot with a rolled up newspaper. The poor thing sat too long I guess😞. Just to add, in recent years I put in a water pump, radiator, and I flushed it a couple weeks ago.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It might not be uncommon... but it shouldn't be.
That's why every fuel system repair procedure begins with... relieve fuel system pressure.
If it does leak... going back towards the tank is one thing. Leaking in the cylinders is a different story.
I would pull the dipstick and put a drop of oil on my finger. If it is thinned out by fuel... it will spread real quick. You can just tell.
Strange... they don't make oil.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Sorry- somehow I’m not getting notifications of this thread, thought nobody cared 😞. Lol . I’ll post photo of fresh oil in a jar soon. It’s dark as heck!
My notifications are random. Sometimes I get too many, other times none.
ekrampitzjr
1,090
Virginia
New development today- I installed a cold air intake- the original had a gaping hole in it that I taped up with electrical tape, and the junkyard didn’t turn up a suitable snorkel. I disconnected the battery for a few hours to clear the pcm. Then I started it and ran it awhile. That was yesterday. Today, I pulled the truck out of my working tent after installing drop suspension, and I let it run for a few minutes, maybe 20 minutes. I went inside the truck and noticed the temperature gauge had gone up to the M on normal, I’ve never seen it above “O” the last 15 times I started it. So now it seems it wants to overheat? Still no smoke from exhaust… it’s running in this photo
With a hole in the intake, the engine would be ingesting dirt and getting cylinder wear. As another member said, it could be rings.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I +1 the bad rings. That or a bad injector. I would try new injectors first.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Let that jar of oil sit for a day or two and it will separate if there are different elements in it. If there is water in it, it will separate almost immediately. If the truck sit for a length of time the fuel system will have to be cleaned out. You've probably got more than one injector screen full of debris and they are stuck open. pouring alot of "cleaners" into the fuel tank will just make matters worse.
trinogt
5
central Florida
Mazda
2.5
The photo of oil was taken yesterday, but it has sat still for about three days now… Also, I removed the gas tank when I had the bed off to paint the cab, and installed a new fuel pump, fuel filter, and a section of hard plastic fuel line that had split causing a leak. I also replaced fuel injectors and regulator at that time.
trinogt
5
central Florida
Mazda
2.5
Thank you to all for the help so far!
I just did a compression test: Right bank, back to front 175,176,186.
Left bank, back to front, 185,180,180.
Tested multiple times each cylinder,
right bank first test of front cylinder was 210(afterward stayed 186),left bank rear cylinder first test was 205(afterward stayed 185). All the rest stayed the same throughout.
Impressions?
Spark plugs looked ok to me. Replacing them as I write this.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Looks like good compression. I do it with all spark plugs removed. Im not to keen on the bleed down test. Never done it. Plugs look lean enough, light brown to white (spares). Where the fluid (fuel) is coming from is hard to tell, you replaced all the fuel system with "NEW" parts. Fuel pressure runs around 32 to 40 depending on demand, idle 30 to 32. Some say forever, aint never had one hold much past a month, but that's just me. I would investigate those "NEW" parts you have replaced. Dirty
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
+1 in new parts suspect. You probably got crappy injectors right out of the box. I notice in rock Auto some injectors are $50 each while others are $50 for the set. A lot of junk parts out there today.
trinogt
5
central Florida
Mazda
2.5
Yeah, I probably bought the latter lol! The biggest problem I have, is that the crank case was filling up with the old injectors installed, and putting new injectors in and I have the same problem. I am looking at odds here? So frustrating. Now today, I started having what sounds like lifter noise! I just can’t win. When the lifter makes noise, the idle gets rough at the same moment. I read somewhere in here that the lifters are usually not the problem with this engine, but that worn rocker arms and push rods are a common issue?
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Probably unrelated, just a bad luck streak. Yea they pushrods aren't very good at moving oil to the top end.
Are you sure its not just the infamous 4.0 tick? Mine ticks for a few mins when cold, then goes away for the day.
