FWD Transmission Problem
BigClemsonFan
Maryland
If you have a front wheel drive transmission in a car, specifically a Focus, and the shifter gets sloppy, what is the most likely culprit? If you don't fix it soon, what potential damage can be done?
rusty ol ranger
2.9 Mafia-Don
7,593
Michigan
177 CID
Stick shift or auto?
Stick shift you may have a bad bushing, or the syncros getting weak, automatic the linkage is pry coming loose.
later,
Dustin
BigClemsonFan
Maryland
Guess I should have been more specific.
It's a manual.
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
The shift cables like to come out of the brackets at the trans. Push them back in and use some tie straps to secure.
