- Mar 12, 2011
- 11
- Edinburg, TX
- Ford
- Engine Size
- 2.3l 4 Banger
- My credo
- Fix it till its broke!
I know this has been asked a few times but this is a slightly different scenario. I recently replaced my filler neck and everything has been working fine until today. I filled her up and noticed it spilled fuel. Now prior to this it was hard to fill up without the pump hose clicking. I replaced it and it worked fine for a bit. It's spilling where the house meets the tank. Think tightening it up a bit more would do the trick? I can't think of anything else that could have gone wrong really. It's on there correctly.
I'm thinking it's topping off and when it rises above tank level it is bypassing the inner hose and spilling from the outer hose. I'm thinking tighten it some more and problem solved. Unless I can use some sort of adhesive where the outer hose clamps onto the tank. What do you guys think?
