ford ranger EGR valve dealer part>>
chadmilliser
MOIRA NY ( 5 MILES AWAY FROM ) CANADA
FORD
ok I bought me a ranger 1995 for 4000.00 ( low miles )
the dealer fixed my problems underwarrente
well now that the bubble gum let go i need help .
I think all the garages around hear are a buch of retards . get this the guy that ( fixed ) my truck went to college!!! Try not to laugh at that !
they told me my egr valve was messing up and they fixed it
they used silcon as the gasket
there was a rust hole in the egr . Dont they cost like 50.00 .. cheap o's
the egr pipe was kinda broke and slid back into the pipe .... DEALER PART AND COST ALOT !
Ive spent over 500$ in fixing need less good parts just because the people at advanced auto tell me that is whats wrong.
this is what I need to know . do you think I can go to napa or somwhere and buy the same size pipe as the egr and then the fitting and then a compression fitting or how can I fix that .
my truck is a 1995 ranger splash 4.0 and the pipe brock right in the middle where that one pipe meats the bigger on . is that suppost to fit in there tight . Can I just put some jb weld on it ? any easy ways to get that pipe out of the egr ?
any help will help . :icon_welder:
chadmilliser
FORD
sorry i miss spelled a few words . I was not looking at what I was typing .
The only reason why I started fixing stuff on my own is when the owner basicly was never IN or they would keep my truck for 3-4 days . They did that 2 times and messed with alot of other stuff. They did not even put the right spark plugs in or even bother to gap them
TRIPLE J AUTO MOIRA NY
Does anyone have any good saying I can plaster on my truck so people will not go there. Ive hear nothing but whore storying ( after I bought it of course )
Bryan22
4
So-Cal babay
94 extd
94 2.3
take it off and weld it?
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
the egr tube that comes off the manifold with 2 hoses.. it then comes up an goes to the erg then on the backside of the egr theirs 2 10mm bolts an the tube does almost a 90 an goes up into the intake.. thats one hell of an expensive tube.. my buddies BROKE right at the 90.. truck was running like poop for a few months couldnt figure it out then i saw the break one late night.. took it ALL off an tig welded the hole then used a die grinder an grinded out the inside of the weld.. worked great an save him a TON of cash.. i looked at my tube the other day an mines got a little hole forming at the 90. so if you can weld it that would be your best bet.. or go to the junkyard an get a new tube
MAKG
19
California central coast
About the only place to find EGR tubes is at the junkyard. They are built like huge brake lines. You might get one shipped from a Western junkyard, as they don't get so rusty (no road salt). Other than that, you're either making your own (good luck finding a double flare tool that big) or buying it from the dealer.
phatcap
the mitten
2.5L
if the crack/hole is small and you don't have access to a welder, use a product called thermosteel. don't use jb weld, it won't hold up to the heat. my egr tube cracked right where it meets the exhaust manifold while i was removing the intake to do spark plugs. instead of removing the pipe, i just undid the egr valve at the intake and tried to push it back out of the way resulting in the cracked pipe. dumb idea.:idiot:
anyway, i tried jb weld first cuz i had some and it just disintegrated and fell off. i found the thermosteel at autozone and that worked. as long as you don't have to worry about inspections...
