Ford 2.3 88-89 cylinder head casting #'s
rseibenick
Does anyone know the Ford casting #'s on the 88 -89 ranger roller cam 4 plug cylinder head. Thanks .
tomw
46
toenails of foothills NW of Atlanta
lima bean
vertical and above ground
If you read the sticky post about the 2.3 lima, you will find that the changes were to the valve stem diameter, but not much else. Later engines had a combustion chamber change, again, from the sticky.
The sticky is the first post in this forum. This is where it lives:
http://www.therangerstation.com/forums/showthread.php?t=9
From what I have read, the cam and roller followers can be installed into a non-roller head without problems. I'd consider doing it, but have only seen one listing on c-list for a cam & followers and it was quickly pulled by the poster.(dunno why)
Oh, I can't answer the question you posted. I do not think it matters. If you have a cam & followers that fit the valve stem diameter, it should work.
tom
rseibenick
Thanks for the information.
