fm145 sloppy shiftier
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
so i was working on the 87 an noticed i have a lot of slop in my shiftier is that normal
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Junk Collector
Truck of Month
4,800
Rapid City SD
One of two things has happened: the shifter housing is loose (bolts have backed out) or the round plastic piece broke off the end of the shifter. Both very common things.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
How much slop? All M/Ts have some play depending on the model. Is the top plate for the shifter tight?
FM145 Shifter Solutions | The Ranger Station
the top plate was loose when i got it i tightend it up but it didnt help much maybe i can get kit to fix it when i pull the shiftier out to do the flywheel repair the truck has 250k miles on it so that might say something
Junk Collector
Truck of Month
4,800
Rapid City SD
Pull the shifter housing off and see if the plastic ball is there. If not, you can try to find something about the same size and replace it... maybe a ball bearing, a hard plastic marble, etc... second option is to find a junkyard shifter, 3rd option is a Hurst shifter ($$$) or just live with it but it's kinda hard on the trans to leave it because you run the risk of not fully engaging a gear.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
well it dosent run or drive rn and ill be pulling the shifter to drop the trans so ill check it then im just trying to make a list of what i need to do while i have it apart and how to do it but thank you
