Floaty steering at high speed
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Hey guys,
Here is the deal:
3 inch lift
33x10.5r15 mud tires
Drop pitman arm
All new steering components, including all ujoint shaft
Problem is she flots at speed. It just doesnt feel glued to the road. Had it aligned at a good shop, but i am thinking that might still be the problem. Is it just height? Skinny and tall tires? Thoughts?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Here is my steering geometry
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Bronco 2
High speed
Pick one 😬
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I am getting old so 55 is fast enough in a b2 and 65 for me is screeming fast
ericbphoto
Overlander in development
16,667
Wellford, SC
6"
Taller rudder and better ailerons.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
My 88 ranger gave me floaty problems at 55+. New steering box fixed it, along with EPAS conversion. YMMV (literally, in this case) :icon_thumby:
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Highly unlikely it is the box.
What type of joints on the shaft?
Do you have the spec sheet from the alignment? The geometry is solid.
Actual toe, caster, and camber... are the critical points if all of the joint and bushings are good.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Sometimes my hat says Gary.
vagabond80
28
montana
stock 4wd
31x10.5R15
I'm in a very similar boat. 1.5-2" lift, drop arm, 31x10.5r15, felt great prior to lift and align. Now feels extra floaty at speed -unless- I'm in a turn. Feels worse when braking/decelerating.
I have a theory that the castor was set too neutral. My tires rub just a bit while turning, and based on the charts here, shouldn't, so it may be a ridiculous way to try to measure, but I'm imagining the angle of the castor bringing my tires a little too far back.
I've been putting off going back to the alignment shop and asking them to confirm/redo, but I'm worried about steering this thing come winter.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I like 5 to 6 degrees caster min...
