Flex fuel help.
Gavinbaine
10
Michigan
Ranger flex
265/75r17
99 3.0 flex fuel. Have a p0176 (flex fuel sensor connector) code. Won’t start. Is there a bypass for this or do I need to find and replace the sensor? Or remove and clean by some means?
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
bad news, that sensor is very expensive. and you cannot clean it. maybe clean the connector, but definitely not the sensor.
it determines the alcohol content of the fuel and sends a digital signal the computer.
attaches to the frame, right in front of the fuel filter.
you can try cleaning the connector, and re-seat it several times.
there exists a "flex fuel replicator" that replaces the sensor and has a fixed 10% alcohol output.
I ran one on my 2000 for several years.
2000 FORD RANGER 3.0L V6 Flex Fuel Sensor | RockAuto
approximately where are you in Michigan?
Gavinbaine
10
Michigan
Ranger flex
265/75r17
Around Sturgis
