factory tach to msd 6al
ford1386
Gardners, PA
306
i have a 94 ranger im currently putting a carburated 302 motor in with the msd 6al ignition control module and it has a lead marked tach signal, but how can i hook this up to make my factory tach work with the v8?
ford1386
Gardners, PA
306
bump................
ford1386
Gardners, PA
306
figured out from msd that i need to buy their tach adapter to make the tach work just need to figure out which wire is for the tach signal on the factory tach i took all the fuel injection wires out of the connectors under the hood so i could clean up the engine bay so it was probably one of those but now i dont know which one....?????????????
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
My best guess is you are looking for a tan/Y wire, coming from the dash, that is for the tach. This is the color of the wire from your engine bay/ECU that you have likely cut off. I do not have an EVTM for your year, but I referred to diagrams at Autozone.com. (It's also T/Y in 1997, which I DO have an EVTM for ...)
I'm not sure what style connectors a '94 has, as all '95 and later Rangers have a big square 42 connector from engine bay to inside the cab.
So , just look in whatever connectors your year has.
Your tach will likely need to be recalibrated, as well. According to my info (I'm sure there's info on this site, I was viewing RPS) there are (2?) set screws on the back of your tach module to claibrate it. This will require hooking up a known tach to verify your reading, but it apparently works well.
Hope that helps.
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
1mean02hd
Chase, MD
5.0L V8
You DO NOT need the tach adapter! Pull out your gauge cluster and there is a pin on the back of the tach that say "8CYL" . Splice into that wire and run it to the tach output on the side of the MSD 6AL box. Done.
Also be very aware of what you are cutting/deleting under the hood or you will put yourself in a big mess in a hurry. As I've said before.... 93s and 94s are bastard children when it comes to the wiring.
ford1386
Gardners, PA
306
ok thanks that sounds pretty easy, but i think i need to get an evtm for a 94 cuz i messed up and already took all the a/c plugs back to two 10 or 12 pin connectors and pulled the pins and wires out then i realized that the a/c system has a plug on the line between the condenser and the compressor..............ooops............
ford1386
Gardners, PA
306
does anyone have a diagram for the 42 pin plug on the firewall this is probably all i need to figure out what i took out that i still need to get the a/c to work
1mean02hd
Chase, MD
5.0L V8
The AC should be fairly easy to figure out. Hopefully I can get to the shop this weekend (we've had a hella amount of snow) and check into that for ya.
ford1386
Gardners, PA
306
bump...................
mini274
Elizabethton, TN
302
i use to haave wat you need but my computer broke so no more... usually any shop will print you out stuff that you need
1mean02hd
Chase, MD
5.0L V8
I've got an EVTM for a 95. I'll check into it later and see if it still has that hub. They are all very similar.
ford1386
Gardners, PA
306
bump.............
ford1386
Gardners, PA
306
bump...............
dagoof
302
Is this true for a 90 ranger as well?
Maybe I didn't need to add that after market tack.......
