External Hard drive disappears
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Do mac's still come with Oregon Trail?
fastpakr
2,843
Roanoke, VA
The earlier suggestion of shucking the drive and accessing it directly may be your last remaining decent option. Short of packing it off to a data restoration facility if the contents are worth that much to you.
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
So I opened it up. First thing I noticed was the silver square, marked with purple, had some burnt areas, marked in red. I assume this is my problem. Getting too hot and failing after a few minutes of use.
Any suggestions or is it toast?
65606
fastpakr
2,843
Roanoke, VA
I'm having trouble orienting myself in that picture - is the photo of a board from the enclosure or the actual controller on the back of the drive?
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
65616
That small board is the one pictured earlier. It's the first thing you see after cover is removed.
65618
Remove that plate and there is another board under that one. I was able to clean it up. There was carbon build up lol on some places. I know the black stuff is "smoke trails" and it's probably toast, but I'm going to out it all back together and hope for the best.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
65621
From my RED arrow and up, all those black dots should be copper colored. Hopefully my little cleaning will help.
fastpakr
2,843
Roanoke, VA
Okay cool - that board is not part of the hard drive itself. You can pick up an adapter to connect to the drive over USB, or if you have a desktop PC you can attach the drive directly using SATA and power connectors inside it.
fastpakr
2,843
Roanoke, VA
fastpakr
2,843
Roanoke, VA
Wait - hang on! I made a mistake. Hold everything...
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
New Egg?
Could I possibly rob parts from a different hard drive. I have tones of random computer hardware.
It seems like just it's the "Power IN" module.
I just made that up so don't kill me.
fastpakr
2,843
Roanoke, VA
Clarification. In one of the previous pictures that I scrolled through too quickly, you were pointing at a separate board and I jumped to that being the one with the issues. Realized a minute ago that the burned bits were in fact on the drive controller itself. That's a problem...
Is the failing drive identical to the working one?
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
the failing one is 2TB and the good (older) one is 500G. That is the only difference.
fastpakr
2,843
Roanoke, VA
That blows my next plan...
I'm honestly not sure what to suggest. If you had an identical drive (control board being identical primarily) and you were willing to take some risk on that one, you could remove the known good controller and attach it to the finicky drive. But that's out the window.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
OK, so it has to be identical? I have a few that are close but not exactly the same.
fastpakr
2,843
Roanoke, VA
We're in a (very) gray area for me. You could look for part numbers on the controllers. I suppose it's possible that a similar drive would use a compatible controller?
