extended radius arm build up
crawlin91
60
Crawlorado
2.9, 4.0
I recently lifted my truck using superlift 5.5" drop brackets and skyjacker 6" coils and shocks and leaf springs for the rear. Everything is starting to flex better now after a short break in period, however the nice soft flex of the skyjacker coils is cut short due to using stock rad arms.
My plan is to cut a set of stock ttb radius arms I grabbed from the pull n save and extend them with use of DOM tube and either heims/johnny joints or bushing setup.
Ive got the basic concept down but have concerns with setting them up with correct caster(not sure exactly how to do that), getting the right frame placement for the radius arm brackets(underneath or outside), and correct angles of the rad arm to prevent tire rub? I was thinking of using bushing style and old f150 style brackets but have heard I will get more flex out of heims or johnnyjoints. Will it really make that much of a difference?
Ranger44
23
Illinois
FORD
4.0 OHV
Use 2" .250 walled DOM tube.
I'd stick with the stock style doughnut bushings.
ckblum
4.0L SOHC
The heims might get you about an inch or two more I hear, but wear-wise I would stay with a rubber bushing. Heims are affected a lot by grit and can wear out faster and are more expensive and look trickier to replace (maybe I am wrong though).
BlackBII
Ranger Custom
Truck of Month
984
UT
Here are mine. I should have built a small amount of caster correction in them, so that the brackets could be closer to the frame, but it's not big deal. I'm using the 5.5 kit as well, lemme get some pics of them installed.
crawlin91
60
Crawlorado
2.9, 4.0
Those look nice, about what Im going for, and that would be great if you could get more pictures.
88mudder
waterford michigan
What size pipe did ya use on those arms?
ckblum
4.0L SOHC
I hope you mean tube. I wouldn't drive on them if they were made out of pipe like sched 40 or anything.
FTSK95
FORD
2.3L
Yea post up some pics I was thinking about doing this on my truck as well. Those Arms look really good!
BlackBII
Ranger Custom
Truck of Month
984
UT
That's 2" .25 wall DOM tubing. I will get some pics today or tomorrow.
crawlin91
60
Crawlorado
2.9, 4.0
what are you using as a spacer for the radius arm end(threaded bushing end) to fit properly into the dom?
BlackBII
Ranger Custom
Truck of Month
984
UT
A melted electrode.
(Weld lol)
Ranger44
23
Illinois
FORD
4.0 OHV
I'd make mine that way as well. I'd only extend mine about a foot though. I'm only going to run 2.5" of lift.
That's only IF I decide to go that route.
BlackBII
Ranger Custom
Truck of Month
984
UT
Mine are 12" longer than stock.
crawlin91
60
Crawlorado
2.9, 4.0
A melted electrode.
(Weld lol)
multiple passes? or is it a tighter fit than that? it just looks like it would need a sleeve of some sort
No members online now.
