Explorer 5.0, m5od-r2... clutch hydraulic help.
Stangman92
NW Chicago
Need help with my swap. I'm converting my Ranger over with an Explorer 5.0 and an F150 m5od-r2. I ran a quick part number reference between the F150 and Ranger. The slave cylinders are the same, so that's what I installed. But the master cylinders are different in diameter and mounting style. Will the Ranger master work even though its smaller? Or do I have to fab a way to get the F150 master to work? Thanks for the help!
Edit: Yes I ran a search, some say it works others say no. I'd like to hear from someone who has gotten it to work.
8,370
Haven't done it but........................
If the slave is the same then it will have the same travel distance for the fluid pushed in.
So I can't see any problem, physics-wise.
The F-150 master might have a bigger piston and shorter throw to make pedal easier to push down if V8 pressure plate has stronger springs, so worst case would be stronger left leg in a month or two :)
Elutheros
129
Central Texas
I think I had to use a 1994 explorer clutch master cylinder to connect with the slave cylinder in my M5ODR2 transmission. Can't remember where I found that tidbit, but its in TRS somewhere.
Stangman92
NW Chicago
Both valid opinions, thanks guys.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
you will need a slave with a 7/8 bore. not a standard 3/4
i used a 89 ranger master 7/8 bore. you will need a ranger 7/8 bore master to work with the slave cylinder. and depending on the clutch you used. the clutch rod will need to be extended from the pedal to the master. i have this exact setup in my truck. used a 89 ranger 7/8 bore master. 90 ranger slave. with the m5odr2 trans from a 96 f150 behind a 302. now putting it behind a 351w. couple things worth noting. the pedal will be stiffer with a v8 pressure plate. the shifter location from 88-96 is further forward than a ranger so a custom shifter handle or the top plate from a 97-02 f150 will cure this. and the firewall seam needs to be bent it to get the trans in plce. but the trans mount is the same. driveshaft yoke and length are the same. so its a great swap.
kevinbmx77
What where the parts numbers?
Sent from my SM-G920P using Tapatalk
jeepfreek
lanesville Indiana
I have the same setup in my truck. Used the stock 1989 master cylinder, used the slave cylinder and the clutch hydraulic line from the M5od-r2 vehicle. Clutch works great!!!!!!
CaptnCrunch
i Have a auto 90 ranger. Going to 5 speed swap it with a v8. I got a 89 clutch pedal assembly plan on using an 89 Master cylinder. today i picked up a M5OD-R2 transmission from a 2002 F150.
from what i gather i need the clutch line and Slave (has old one on the trans) from the 2002 F150 and the line will plug right to my 89 Master i want to use. can anyone confirm this ?? if so i would list all the part numbers
96 rang
Plains tx
Ford ranger
I have a 96 ranger 5.0 swap can i use stock master cylinder on 2002 4.2 m5r2 transmission
