Escort's Project Family Wheeler
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
And it is about time you go back to Barstow.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
NP208, will that work with this transmission?
Sent from my SM-N910T using Tapatalk
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Yup. The np203, 205, 208 (okay all fullsize transfercases) have the same bolt pattern.
I do suggest getting one with fixes yoke outputs. Can be found on full-size f150s with extended cabs. I have one from a standard cab and is a slip yoke but seeing as you are a flex whore, you run the risk of the slip yoke coming out.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
I have a friend that is selling a 82 bronco for 300 with no title. But I don't need the whole truck
dangerranger83
54
Lafayette, IN
I'm told (and read somewhere) that the Bronco have a different pattern than the F-150s
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Waiting for the tow truck to take it to the transmission shop. I just decided to let them do it all.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
This way you get a warranty as well.
Sent from my iPad avoiding something that I should be doing right now.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Exactly.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Picked up a BW4406 today.
dangerranger83
54
Lafayette, IN
Those are pretty big (tall) but should fit under an explorer.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
I did a little research on them. It will fit the explorer better than a ranger. I also have to modify it a little or try to find a slip yoke eliminator
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Oh, and it's a manual shift that came with all brackets, linkage and shifter and front shaft.
dangerranger83
54
Lafayette, IN
Just have to cut a hole in the floor.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
