Worked on it some today. Got the power mirrors on and working. Thanks legoms013, they look nice.
Also moved the axle forward about a 1 1/4". Also worked on the trackbar bracket some. The bolt I had at the engine crossmember for the brace was loose and was only a 3/8 bolt. I drilled out the hole bigger to 1/2" bolt with a locking nut. It is much tighter and will take it for a drive tomorrow to see if it made a difference or not.
You can see by the lack of paint how much it was moved...
Next thing I will do is fix the front bumper. Looks like crap and the tire almost rubs.
I still need to put the longer shackles on to make it level, but first I need to put the longer brake hose on. The bleeder screw on the wheel cylinder is froze. I don't want nor have the money for the rear brakes yet so that will be one of the last things fixed...
