NIGERIAN RANGER
- Sep 13, 2020
- 28
- Lagos, Nigeria
- Ford Ranger
I have been having issues of prolonged startability with my engine recently. I realized that before the engine starts, I'd have to spray starter fluid into the intake manifold, before the truck starts. And each time it starts, and runs, it idles smoothly. But immediately the engine is turned off, starting the engine immediately, would be a problem. Engine cranks for a long time, and acts as though it wants to start. When the starter fluid or gasoline is sprayed into the intake manifold, it starts.
I'm thinking, this could be a fuel pressure loss related problem, since it's appearing as if there's insufficient fuel supply at the rails, needed to crank the engine. But the surprising thing is that, immediately the engine starts running, after priming with starter fluid, it idles no matter how long, without shutting down or whatsoever, until i shut ut down.
There also is some kind of bucking or so, under heavy acceleration, but ceases, during light loads.
This has happened to me once, where the the suction fuel hose on the fuel pump had ruptured, causing fuel pressure losses.
This time around, I'm looking at getting another pump to try it out.
