Can ya give me the engine size? Also...does the engine cut out as soon as you turn on the ac or does it happen after it has been on for a while? Was it blowing cold? Can you tell if the compressor is trying to engage or does the engine die before you can tell?
It's a 2.5 liter four cylinder. The compressor does come on. It doesn't die immediately. It usually happens if I've been driving and come to a stop. The air is cold. I have noticed that the engine doesn't pick up idle speed, as I have seen other vehicles do when the air is turned on.
I sounds like you have a vacuum leak on one of the lines...which is common for engine stalling when comming to a stop. Check all you lines for holes or tears...a can of starting fluid can sometimes help. With the engine running spray a small amount around each line...if the engine rpm increases at any point, inspect that line you just sprayed. Good luck.
Mine used to do that a loooong time ago and it was my IAC valve. I would check for vaccum leaks (even small ones could do it) first before swapping out the IAC though. LAter.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
