MadMax_636
- Nov 7, 2019
- 47
- Age
- 28
- Georgia
- Ford Ranger
- Engine Type
- 2.8 V6
- Engine Size
- 2.8L
- 2WD / 4WD
- 2WD
- Total Lift
- However much it goes up when I get my fat ass out.
- Total Drop
- How much it goes down when my fat ass gets in.
- Tire Size
- Dry rot and old
As the title states. My spark plugs are fouled and my engine wont stay running. Its acting like theres a vacuum leak. Ive used stater fluid everywhere and the only point that seemed to be a problem area was the EGR block off plate/gasket. I have since replaced it and it still wont stay running. the carb bowl is full (Fuel is pumping and getting to the bowl) but shes only "runs" if I put a rag/towel over the air horn. She doesnt like it when I pump the gas. It stalls out.
Me in my infinite stupidity decided to mess with it at 1 (When I got home from work) because the PCV was causing a high idle and kept causing my timing to go out of wack. So I decided to **** around with it until it stopped running....
