SteveRanger
- Dec 30, 2016
- 0
- Ford
Hello all,
I've been having a few electrical problems with my 1999 Ranger XLT. Everything is stock.
Problems:
- dim headlights
- radio turning itself on while driving
- radio switching to the CD player from FM radio and displaying " no cd,"
- CD player activates like it is trying to find a CD when the headlights are turned on with the vehicle off.
- AM radio buzz with alternator/blower motor
- Key chime with door open doesn't always work (sometimes after waiting or jiggling the key it will)
- Loss of all power when attempting to start. (Could temporarily solve by detaching and reattaching a battery terminal)
I have solved some of the issues:
- New headlight housings and bulbs (Sylvania XtraVisions)
- replaced positive terminal clamp on battery
- Cleaned and greased all chassis grounds I could find in the engine compartment
- one by the battery/radiator
- one on driver side near fuse box
- one on passenger side near blower motor
- one top, center firewall
- Engine strap to top of firewall
*I was unable to reach the starter or the strap at the motor.
- I also found one ground behind the passenger kick panel in the cab. I looked for more, but couldn't find any.
This has solved my dim headlights, AM radio squeal that corresponded with the alternator/blower and I swear my speakers sound better and have more bass! It also has a stronger crank.
Still a problem:
- CD player's motor turning on when the headlights are activated with the truck off. I've never checked to see if it would play if I had a CD in it with the truck off.
- I haven't driven enough to see if the radio will come on by itself or switch from FM to CD yet. I can actually hear AM stations now, but the 700 range bands have a high pitch whine to them. Other stations are very clear though for the first time in a long time.
- Intermittent key chime
Are there any more grounds that I should clean? Thoughts?
Thanks
Stephen
Problems:
- dim headlights
Still a problem:
Thanks
Stephen
