- Sep 21, 2007
- 680
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (1½" suspension), BII 4" suspension
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 33"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
@Rangergirl92 ,
In my experience going cheap on an electric fan ment the fastest road to failure. I've used Flex-A-Lite, Be Cool, Mr Gasket and Permacool electric fans with expected results and life of component life.
The only time I had an electric fan die sooner than expected was when I bought the cheapest "no name" fan that I could find.
While I stick to the 2,800+ cfm, I have used 2,500 and another rated a little less, without issue. A 2,800/+ cfm works with authority and is worth a few extra pennies.
Here is a lower rated model that does work well; it includes a shroud and the controlling electronics. As pictured from "Summitracing.com", though also available from others sources; it is Summitracing's rebranding of the Flex-A-Lite Black Magic line fan. From memory, it is underrated, it behaved more like 2,500 to 2,800 cfm.
2nd pic is the nearly identical fan from a different source (4wheeldrive parts), says 15" @ 3,000 cfm.
