DuraSpark II installation
BronKitis
Spanaway, WA
2.9L
Can someone please explain in detail how to wire the Duraspark II ignition utilizing the factory harness as stated in the tech articles? I'm easily confused :dunno:
I'm sure I could figure it out given enough time but I'd rather just have it so I can dive right into it after work this week. Thanks a lot!
kimcrwbr1
46
maplevalley WA
2.8l
Duraspark II or duraspark? I believe there is a difference what color is the grommet on the module you have. It needs to be blue for the wiring diagram in the tech library. There are two plugs one 2 wire and one 4 wire? It is easier to use a internally resisted coil to eliminate the start circuit for the coil. Does you engine have a iron or steel cam the gear on the distributo must be matched with your cam? Have you bought parts? You can get the 1 wire HEI distributor and makes wiring yippie skippie.
BronKitis
Spanaway, WA
2.9L
Yarded entire motor and ignition out of a 1984 Full Size Bronco which should be the II, right? That damn resistor wire is what's spooking me out!
Sent from my SGH-M919 using Tapatalk
