8cylRWD
- Dec 4, 2009
- 0
Using my 94 ranger 4 x4 4.0 A4LD with trailer towing pkg (incl external trans cooler) I pulled a 3000 lb trailer around town for about a half hour, outside temp 85 deg. Truck did not like the heat, belched ATF out the bellhousing, even left left oil spots on the trlr. Offhand I don't remember the axle ratios, but somewhere around 3.31 or so. Pretty tall gears with 29" factory tire size. Added a quart this morning to bring it back up. Drove it today not pulling the trlr, no issues.
Is there a way to set up an A4LD to lock-up when it hits third, and stay in lock-up through 4th, and also until you slow down to the point where the 3 - 2 downshift occurs, like an A4OD does? This truck is on the convertor at 2000 - 2600 all the way to 47 mph around town when pulling the trlr. Lock-up speed is the same whether you're in 3rd or 4th. This would help on gas milage also if it could be done. Most of my driving hours are urban/suburban. thanks
