Driveshaft swap
derekj
Squamish, BC
Ranger 4wd
Ok - I hate to bring this up again but I have searched for info on using the explorer front driveshaft in the rear of a B2 and am still a bit confused. My truck has the silly cv shaft so I would like to replace it. I got a front shaft from a 93 explorer but am wondering what I need to do to get the shaft to work with the flat flanges on my truck. Do I need to change the flanges on the t case and the rear end or do I need something to bolt to the u joint cups on the driveshaft? I really dont want to spend $500 on a new shaft right now. My truck is a 88 B2 with a 7.5, A4LD, and 1350 mechanical t case.
Derek
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Since you have a '88, that shaft will need to be shortened 2.5"
This is what you need:
1.
A 1354 front t-case output yoke to swap out your rear t-case flange,
2.
The front u-joint flange off any '88-'97 Ranger/Explorer rear driveshaft (this to fit your BII 7.5" pinion flange... if you plan on a 8.8" swap in the future, you'll want a REAR flange off any '91-'97 RBV rear driveshaft).
hope that helps
derekj
Squamish, BC
Ranger 4wd
I plan on putting a 4" lift in the truck by summer time - would I still need to shorten the driveshaft that much?
Derek
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I'd probably go 2" shorter in that case.
derekj
Squamish, BC
Ranger 4wd
Thanks - that was the info I was looking for.
Derek
