drive shaft for 5 spd from donor mustang.what to use?
svtcards
137
Lyman maine
302
3'' front 4''back
I was wondering what to use for a drive shaft for my v-8 swap.i looking to put a 5.0l with a 5spd manual in my truck.donor car im currently looking for is a 1987-95.not sure if shaft from donor car would be perfect fit or my current drive shaft from my 2.3l trans would work.any help would be great.
The Mustang shaft probably won't fit. My 92 Mustang is much shorter than my 87 Supercab.
I'd take the front yoke from the Mustang trans down to a drive line shop, along with your measurements, and get one made.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
So on my 90 ranger. I’m using a t5 from a 95 mustang. And the stock ranger driveshaft fit perfectly. No issues.
My truck is a regular cab short bed FYI
svtcards
137
Lyman maine
302
3'' front 4''back
sweet!mines an 1987 shorty.pretty sure its the same drive shaft.good to know.all good info.thanx guys
svtcards
137
Lyman maine
302
3'' front 4''back
1 last question 2 rangerfabworks.what did u use for a trans crossmember on your t5 or any mustang manaul 5.0 trans?did u have to make one up or did u modify the mustang one?
svtcards
137
Lyman maine
302
3'' front 4''back
Old post I know.but your rangers yoke fit in your t5s tailshaft?my mustang yoke is bigger then my rangers.not sure if I can buy a bigger yoke that could fit my rangers stock drive shaft.what was your stock engine in your truck?4.0l?
RangerFabWorks
715
302
my stock truck was a 2.3 and a m5odr1 2wd. And the t5 was from a 95 mustang with the 302. Yes my yoke slid right in no issues.
svtcards
137
Lyman maine
302
3'' front 4''back
Is your truck lowered
Is your truck lowered?did u have to do anything with the pinion angle at all?
RangerFabWorks
715
302
no I’m at the stock height. And nope. Pinion angle was left alone. No issues.
Ramcharger90
1,708
N/A na
306, Bcam,
I had to get one made for my 90 single cab regular bed.
51871
I used 1650 series u joints for more strength. Not necessarily needed but I plan on making alot mor power at some point.
svtcards
137
Lyman maine
302
3'' front 4''back
I had to get one made for my 90 single cab regular bed. View attachment 51871
You couldn't get your stock drive shaft to work?
svtcards
137
Lyman maine
302
3'' front 4''back
Ramcharger90
1,708
N/A na
306, Bcam,
My 2.3 drive shaft was to long for the T5 it was perfect for the m5odr2.
svtcards
137
Lyman maine
302
3'' front 4''back
Mine stock one is real close.maybe an inch to long but I haven't cut hole in floor yet or bolted anything to it's permanent spot either.it ll be close that's for sure.need to replace slip yoke also to change it to 28 spline since mine is 25.
svtcards
137
Lyman maine
302
3'' front 4''back
does your t5 shifter seem to lean to the driverside or does it sit level with your floor?mine seems to lean towards the driverside.not sure if that's normal or not?
