Door Not Closing Handle Stuck Up
GrumpierGrunt
11
Staten Island, NY
Ranger 3.0 FF
1999 ford ranger v6 FF single cab.
My driver side door handle stays in the up position when I open it. If I go to close it in the up position, it just bounces right off the striker. If I fiddle with the latch or put the door handle down, it’ll close normally.
any help is appreciated.
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
Sounds like it could just be froze up a bit inside, some corrosion or could be a broken return spring. I would use pb blaster or equivalent to soak the internals and run the latch through its paces a few times to see if that frees it up. If not id take the panel off to actually look at it.
Ps i dont much belive in wd40 i see it as an electrical connecter dryer outer lol. Use something with an oil that will stick around, once any corrosion is cleared o use a silicone spray lube on e brake ratchets, door mechanisms, and such other frequently used places. Sticks around much better, does a better job, i hate squeaks.
ThatOneGuy
575
South sound
Ranger Explorer
Glad you found the issue, but i get it who wants to pull a door panel if you can ask a question and get a secret tap here and twist this instant fix that requires near zero effort lol.
