Door hinge pin and bushing for 2007+ Ranger
11
Victoria, BC, Canada
Anybody replace their door hinge pins and bushings on a 2007 or newer Ranger? I have no problem finding them for 2006 or older.
Cheers
Edit: LMC lists their pin and bushing kit as fitting 93-11s. Looks the same as the Dorman kit.
sgtsandman
Aircraft Fuel Tank Diver
12,655
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I've never had a need to but the year listing is consistent with information here on what fits and what doesn't in a given year range.
11
Thanks for the input sgtsandman. To clarify, do you mean the 93-11 is consistent with the information here (and by "here", do you mean the forum)?
sgtsandman
12,655
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Yes, 93-11 is consistent with the information here, depending on the part. Others are 98-11 due to the redesign of the frame. I don't believe the cab changed significantly form 93-11. And here means this forum and another Ranger forum I've belonged to for a long time that is not associated with this one other than perhaps some mutual members.
gw204
St. Leonard, MD
Mazda B3000 SE
I've used those Dorman hinge pins on an F-150 before. The bushing are junk. They broke apart when I tried to press them into the hinges. On the second set, I ended up sticking the bushings in the freezer, opening the holes slightly and then heating the hinges to get them the expand ever so slightly so the bushings would go in.
After going through that mess, I just shimmed the bottom worn out hinge with some washers. That was way easier.
