- Sep 22, 2007
- 7,494
- Michigan
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 177 CID
- 2WD / 4WD
- 2WD
- My credo
- A legend to the old man, a hero to the child...
They do provide the 48/52 power split but they dont only send power to the rear unless the front slips. Both axles get torque all the time. But if a wheel slips then the brake is applied to that wheel to send power to the other wheel. In what matter it does this depends on which mode you select.The ZJ's did great in snow, I think because they were so well weight proportioned front/rear. The first ZJ I had was full time 4WD and used the NP249, no computer input garbage that they use now. It was a 48/52 front to rear torque split, and could send all power front or rear if needed via the viscous coupler in the transfer case. Today's versions rely on the ABS/traction control/stability control systems to tell the 4WD what to do and when....they're rear wheel drive until traction loss is sensed and then it will decide if and when you get power to the front axle in many cases it isn't when you want it LOL. My 2nd ZJ had the Selec-Trac 4WD using the NP242 transfer case, which is by far better as you get full time 4WD via an open center differential rather than a viscous coupler that was prone to failure as the vehicle aged, and you also get part time 4WD mechanically....and you get the 2.72:1 low range as well. The only thing better was the WJ's from 1999-2004 that had the Quadra-Drive 4WD system which utilized a gerotor pump in the transfer case instead of the viscous coupler, and had Varilock front and rear axles which would progressively lock up to a full on locker if needed but revert back to open differentials when additional traction wasn't needed, and this was a bare bones stock WJ with that capability. The Quadra-Drive used the Quadra-Trac NP247 transfer case, but added the Varilock differentials. After 2004 they did away with the front Varilock, and went to just a rear now they only have a rear E-Locker, and use the brake bias torque vectoring system up front.
The Grand Cherokee is quite comfortable even in the 1st gen ZJ platform and solid axles, yep solid axles up until the end of WJ production in 2004...2005 WK's went to independent front suspension with rear solid axle. WK-2's starting in 2011 and models since are all independent 4 wheel suspension. I haven't ridden in anything newer than a WJ, but I'd bet the WK's and newer WL's are even more comfortable with the coil spring independent suspension. These are also, all built on a Unibody platform.
So its fulltime 4wd not AWD like a subaru or something.
Now in 4low it takes the differential action out of the Tcase and locks everything togther in a 50/50 split similar to the traditional 4wd we are all used to.
Atleast thats how i understand it.
There were no 3 row WK2's, the L didnt start untill the new model came out this year. The 5.7L has been an option since 05 i believe across all trims but its rare on anything lower then an overland. There are some limiteds out there with it but i didnt find any laredos but i did read V8 laredos exist.5.7L HEMI is only available in the Grand Cherokee L Overland and higher trims which is the 3 row Grand Cherokee. I figured they'd have a higher tow capacity but they don't, pretty much the same 7200lbs as my 08 Explorer with the 4.6L V8. So I guess no point in getting the V8 LOL. Wouldn't mind a newer Grand Cherokee at some point I really miss my 96/98 ZJ's in the winter. The Explorer's "Auto 4x4" isn't anywhere close to the 4WD system in the Grand Cherokee back then...would be interesting to get into a WK2 Grand Cherokee to compare LOL.
Wait...you researched a vehicle before you bought it, that's it, someone's gotta like limit your login or something LOL....
