- Jan 23, 2011
- 982
- Bronson Michigan
- Ford Bronco II
- Engine Type
- 2.8 V6
- Engine Size
- 2.8
- 2WD / 4WD
- 4WD
- Total Lift
- 6” skyjacker 2” body
- Tire Size
- 33x12.5
You mentioned a noisy dizzy.have you checked under the cap for loose rotor? Are you using the standard small base and cap or did you upgrade to the larger size? The small ones are known for scattered spark.
Aside from what we have talked about I don’t think I can help. I went over how I set mine up. They both run great.
