Do I need to replace cam chain adjuster ?
Roert42
5,012
Kintersville, PA
Ranger XLT
4.0 SOHC
I finally got the 500 miles on and changed the oil, I dragged a magnet in the oil in the drain pan and didn't find any metal ? I heard it's not unusual to have some after the break-in. I unintentionally switched it to NAPAs synthetic blend not sure if that's any good so I'm going to do some research and might switch to something else on the next oil change. My part time job is delivering parts for NAPA and I get most everything ar cost. The motor is nice and quite, the only noise is a heat shield that rattles sometimes. Now I have a motor that is as good as new so if I take car of it , should out live me 😀
I think the napa gold synthetic is supposed to be the same as valvoline synthetic.
sgtsandman
Aircraft Fuel Tank Diver
12,726
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If it is, the OP will be happy with it. I use Valvoline Synthetic a lot.
dashhho
51
Canada
Mazda B4000 SE
I am curious if anyone in colder climates use 0w30 or even 0w20 in the dead of winter to help cold start engine wear.
sgtsandman
12,726
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I doubt I qualify for the climate you are asking about. PA has it's own kind of cold with the humidity but it doesn't typically have the lower temperatures of further north.
I run the stock 5W-30 spec but I also have a block heater, oil pan heater, and battery blanket because I'm a mechanic in the military. Cold weather makes make me hurt. The block heater and oil pan heater make a world of difference in the length of time the engine takes to warms up. Now, the hole in my system is it works when I'm home but if I'm elsewhere, I don't benefit from it since I don't have a place to plug in.
Blackstone testing has shown that wear has been good with no concerning numbers in the 2011, 2019, and previous vehicles I've owned. Granted, I run full synthetic over pure petroleum or synthetic blend oil. So, that makes a bit of a difference.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Yes, live at 9000ft elevation in the Rocky Mts; Winter is basicly 6months long, with cold morning temps down to -30f.
So my 6month oil change routine is 0w30.FullSyn each Spring & 0w20.FullSyn each Fall.
Done this several years now on both the 2001 V6~4.0L~SOHC & the 2008 V6~3.5L~DOH, without issues.
Seems to have helped get oil moving quicker & minimizes wear in the engines during cold starts.
If in a more typical milder climate, I'd use 0w30.FullSyn year round.
If in a hot climate (SoCal~Florida), I'd use 0w40.FullSyn year round.
Click here for more info.
