Do i need a Relay for HID kit?
Wigifries
2.3
I have an 87' Ranger... i got a HID kit for Christmas, 8000K, Will i need to wire up a relay so i dont fry the wiring harness, or no relay at all?
Any Comments Would be greatly appreciated!
Thank You!
machine090767
Minnesota
5.4 Triton V8
Perfection is worth the wait
how does a HID kit work on a sealed beam headlamp system like the Gen I has?
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
It replaces the whole sealed beam unit with a new housing designed for an HID bulb.
As for the relay I'm not sure, someone else a little bit more versed in electrical should be able to help you out.
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
i believe the HID balast itself works as a relay, the oem wiring just activates the balasts. the bulbs are powered via a stronger wire coming out of the balasts.
as of using them on sealed beams, u need to convert to non sealed ones first. that is housings made to use disposable halogen bulbs
EERNGER
Michigan
I think RSH is on the right path, im thinking the ballast takes care of the relay part of the equation.
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
i really think so, since all the HID installs ive seen, ive never seen a relay. all i see is the oem wiring activating the balasts and them balasts taking power directly from the battery and then to the bulbs. the oem connectors arent even used
The_Dealer
10
Macon, GA
Duh!
the ballast is the relay. u will need the aftermarket "diamond" lenses that use the h4/9003 bulbs
06RangerXLT
54
Georgetown Ontario
just connect the balast to power. plug in the balast o the bulb and you have light. no relay needed
