Do i need a new engine?
supercrawler
so cali
ford ranger 3.0
Just purchased 2008 3.0 ranger with 224000 miles.
Noticed misfire so went replaced plugs wires ignite coil and did compression test.
1) 175
2) 176
3) 175
4) 127 ( wet test it jump to 190 so bad ring )
5) 165
6) 175
DO I NEED A NEW ENGINE?
It run good just little vibration on engine.
Check engine light on and off says misfire 4cylinder.
No smog.
The guru and mentors what do you suggest?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Short answer yes. Long answer no.
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would just drive it while getting my ducks in a row for an engine change. When it gets worse... maybe even next week... change it.
rubydist
858
Denver
Ford Ranger FX4
Some people have had pretty amazing results with engine restore products. There are several brands, each with their own claims of why they are the best, but I have seen tests where one of those products brought the bad cylinder up to normal compression and it stayed there for a long time. It can't hurt to try in your situation.
franklin2
1,758
Virginia
Bronco II
You already have a known problem with the one cylinder. Everything else has a lot of wear in it with all those miles. So I would plan on a rebuild or another engine. Things don't last forever.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'd call Guinness... having 4 cylinders within 1 psi of each other is probably a world record.
supercrawler
so cali
ford ranger 3.0
I will eventually rebuild original engine rather than remanufacture engine, When the times right.
Thanks so much all.
