DIY Electric fan controller
Decker
Hi folks, I found a circuit design on a 240Z forum and adapted it for a Taurus/Mk VIII dual speed fan. Please check it out and let me know your thoughs on it. :icon_welder:
alwaysFlOoReD
5,132
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'll make a comment once I learn to read diagrams. I just bought a book on the subject.
Richard
Decker
Hehe, I just started with a hand drawn diagram with 3 relays and store bought controllers and spent about 2 hrs in Visio figuring out what all those little diagrams are. I know those relay diagrams are wrong, I made those up :D
martin
26
St Bruno, Quebec
1991
If you look on the side of the relays there's usually the correct diagram. It would make things much easier to follow.
Decker
Think you might have misunderstood what I was trying to say... Visio didnt ahve a diagram for a relay. It was just a rectangle with an indicator for AC, DC, Mag, etc. That's why I indicated the terminal number on the circuit.
Everything else is the correct diagram/icon, from what I can gather.
Decker
No one else? Thought it would be more useful :) I'm going to prototype this using a Crown Vic aux power distro unit or a Bussmann RTRM fuse/relay panel. I cant seem to find what I actually want, a modular system.
Also, I'm looking for a circuit design software for automotive circuits. Everything I can find is for discrete circuits.
jules15
Wow this is pretty cool. I've been looking for something to control my fan. Question: Where does this temp switch go? On the radiator?
Bob Ayers
16
Durham, NC
Here is a mod to the circuit that is needed for AC:
However, I suggest staying with the OEM mechanical fan, which will cool better, and be much more reliable.
06RangerXLT
54
Georgetown Ontario
I did the same thing with 1 temp sensor and 2 relays. high low and cycling with ac. Bypasses ac to run high if it gets too hot.
1 temp sensor
1 dual pole relay
1 single pole relay
10 gauge for the fan
16 gauge for signal wires.
modified to fit in the factory fan shroud, unless you look for it, it all looks stock.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
I have 2 switches, on on/off and the other is high/low. I also run 2 relays for the high/low settings. I am running the 2 speed taurus fan.
85_Ranger4x4
17,953
SW Iowa
I was told the threaded pipe sensors that actually touch coolant are much better than the ones that you poke in the radiator.
I got a painless kit, with a sensor and relay. It was pricey and knowing what I know now I would just get a relay and sensor.
With a 302 and a two core 91-94 automatic/AC Explorer radiator my single speed pusher fan barely kicks on and has no problem keeping it at 190 or below... sounds kinda like a supercharger but it works fine.
