emmzz
- Sep 10, 2021
- 1
- Oregon
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
- My credo
- Can't make it worse if it's already broken...
My dash lights went out on me, and I'm feeling kinda stuck. And maybe not by finding a problem, but by finding the part itself?
So far, this has been what I've found:
Fuse #1 was blown. All other lighting still works.
Fuse #1 was replaced, and immediately blew again.
Following a Chilton manual, I can get the dash lights to come on again if I remove the dimmer switch and wire straight from the incoming power to the dash. According to them, they say this means I should replace the dimmer switch.
And here's where the problem comes in:
Ford doesn't manufacture the switch for the 2007-2011 Rangers anymore, and neither does anyone else. The whole internet seems to be out of stock. Including Amazon and ebay. Sometimes, dimmer switches can be refurbished, but I don't know if this is one that can. In my searches though, the ones for the Fusion and Edge of the similar era look very similar, minus the bumps on the wheel.
So, I guess, can I either service my existing dimmer switch, or use the similar one from the Fusion as a replacement?
