Difference in A4ld Torque Converters
igiveup
Edmonton Ab. Canada
Hello
Does any one know the difference in torque converter between a 85 2.8l A4LD and 94 4.0l A4ld. Ford has different part numbers for them.
igiveup
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Mainly stall speed.
igiveup
Edmonton Ab. Canada
Hello
I am using the 4.0l torque converter on my 2.8l so how would that effect the transmission?
If you need any more info on my setup please ask.
igiveup
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
Using the 4.0l converter behind the 2.8 may make the engine feel like a dog because of the lower stall speed. A 2.8 converter may make the 4.0l rev more ( like a high stall in a race car ) due to the higher stall speed.
igiveup
Edmonton Ab. Canada
Hello
Well that explains why its seems so under powered. Time to get a 2.8l converter. Any suggestions on a good budget one? Make + Model?
igiveup
