difference in 98+ superlifts?
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
what is the difference between the two lifts available?? i found one used that says for a 98+ and i know they added something for rangers that are 2000+ what is this difference in the lifts?? thanks
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
There was the switch from PVH locking hubs to live spindles mid-year '00.
I also seem to recall something about the brakes were upgraded around '03 maybe? Maybe someone else can confirm that one...
I don't think the brake thing affects the lift, however the '98-'00 PVH knuckles do have some differences that probably won't matter if you either do a manual hub swap, or you have live spindles on your truck (if this is for your '07, it'll have the live spindles as stock).
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Larger disc brake in ’03.
Some of the kits, which one I do not know, have built in provisions for larger rotors and will allow the upgrade to the larger OD.
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
thank you, i found one used...from a 99, or 00. just need to make sure itll bolt up ok...i know they added something to the kit? im not sure what it is but there used to be to kits available the k357 and the k358 im just wondering what changed??
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Not sure but has to be in the Knuckles, must be two mounting locations on some of the kits.
Contact SuperLift directly.
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
as far as i can tell the difference is the abs lines? i just need a clear answer lol, i called and he says the knuckles were different...i just need to know will the k357 kit work for an 07....
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Sorry can’t say anything more than I have without getting you in trouble.
Good Luck in finding the info, it has to be out there somewhere.
Maybe someone else will pick up on the posts and help out !
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
As far as I've found out the newer knuckles are predrilled in 2 spots for difference sized rotors, which looks like the lift I'm looking at has the knuckles like that, I'm not sure what's in the hardware bag they added into recent kits is tho, but I guess ill hope for the best?
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,862
Pittsburgh, PA
2.3 EcoBoost
1.5"
Ford went to a larger balljoint in 2001 so the knuckles will be different. Also a larger brake rotor at that time but I don't think that or the hubs make any difference. It is the ball joints.
