No it didn't but you "may" be able to add one
You need to find your OBD1 connector in engine bay, it looks like this:
https://www.therangerstation.com/tech_library/OBD_I.shtml
The slot labelled Self-Test OUT would be the CEL(check engine light) bulb ground if you had one
Put a test light(or volt meter) from Battery Positive to this slot
Turn on the key, engine off
You should get test light on or show 12v on meter, because slot is now grounded by the computer
Start engine
Light should now be off or 0v on meter, assuming no Codes in computer, lol
If so then you could install 12v bulb in dash, cluster will have 12v key on power, tap that wire, there will be 2 or 3
Then run ground wire from "the slot" to that bulb
You now have a CEL
But smog place should be able to look up your model and see there was NO CEL installed at factory
