Detroit Diesel 353 Build
Ramcharger90
1,708
N/A na
306, Bcam,
So I have decided to go a different direction then previously thought. I am doing a 353 Detroit Diesel in an 88 Ranger still with the solid axle swap.
The engine
Detroit diesel 353 silver. Found them currently saving up for one with low hours and with a turbo and blower on it.
56741
I am on the search for jakes also.
Bellhousing
Sae 3 to nv4500
The transmission
Nv4500
If I dont find one with the 1.25 inch diameter 10 spline input shaft I will have to change it out.
Transfer case
Undecided
Possibly a np205 if I find one with the correct splines and size input.
Drive shafts
Will need to be made
Exhaust
Straight pipe.
Alternator
Isuzu NPR with vacuum pump on back
56742
Axles
8.8 31 spline
Dana 44 wagoneer
Or dana 60's already cut down for a wrangler. I have to measure them and see if they are wide enough.
Lift
4-6 inch coils up front (F250)
Leafs in back
3inch body lift to fit engine under hood.
Rewire
24v
Starter
Air starter
From what I read the tooth count is the same on a 353 and 453.
The front end will flip open like a semi tractor but I may have to make the bumper flip with the rest of the truck.
56745
Hopefully the end product will be a mix of
56743
56744
56765
Ramcharger90
1,708
N/A na
306, Bcam,
I started tearing out that nasty interior.
56746
56747
56748
This seat would not move so I got a little creative.
It went well....
56749
56750
Its amazing how strong 2 bolts can be....
56751
56752
56753
56754
Next I yanked the 2.9
And unnecessary wiring.
56755
56756
I drained the (OIL) first.....
56757
56758
The frame is fairly solid, We will see after blasting....
56759
56760
56761
56762
56763
56764
bilbo
922
South Florida
2.3L
I wish you well, I thought about doing this with mine as there was a 3-53 nearby for cheap. Until I saw the weight. But the F250 springs hopefully will help you out there. I love the sound of the 2-stroke Detroits. They had a dozer at a steam show once with two 6-71s. The dozer was split down the middle the long way with an engine and track drive on each side. The glorious noise coming from that thing made it hard to stand up! On the other hand I'm glad I didn't have to spend 8+ hours per day operating it either. I haven't given up on putting one in a pickup just think I'll use something bigger. I'll be watching this!
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
That seat was not a willing participant at all. :ROFLMAO: And the milkshake is no Bueno.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Mmmmmmmmmm chowdah!
1st off, there's no chunks. 2nd its even worse than Campbell's. And C - lay off the wacky tabacky for a bit it's clouded your mind. LOL
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Ok ok after a second look you are right, it is clearly a bisque not a chowdah...
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Maybe a hollandaise sauce for eggs benedict.
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If it wasn't for the oil filter and drain pan... it kinda looks delicious!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Ramcharger90
1,708
N/A na
306, Bcam,
Pj might still want that 2.9...... it may have 4.0 pistons in it. The guy I got the truck from wasn't sure . He drove out to Iowa to get it. I officially made 50 dollars buying the truck after scraping the cats. Paid $750 for the truck and an 5.0 exploder chassis. Sold that whole chassis the 5.0 rear everything.... for $650 and the cats for $150.
