rover56
- Jan 20, 2023
- 15
- texas
- ford ranger
Hey folks,
Went out to my Ranger last week, turned the key and dash lights flashed on, and heard one "click", then everything went dead. Currently have no dash lights,,head,or tailights, nada. Checked battery first and though in its last quarter of its life, it still holds full charge. Then checked the following fuses in the engine compartment box, (#7-starter solenoid, #9-ignition switch, #11-PCM relay #21-PCM-keep alive power, #39-Pcm power, #44-ignition coil and #48 starter relay. Then went to fuses in the kick panel I thought were related to starting. #10-cluster(run/start), #21-starter relay coil and #33-Instrument cluster battery feed. Positive battery cable clamp was pretty corroded so tried to find new replacement harness section, but thats not available new, so ordered a splice repair kit, installed it, made no difference. Ordered a OBD2, plugged it in and it showed power with key off. Turned key on and power died. Was thinking it may be a bad/broken ground somewhere, now thinking it may be in the ignition switch. But why no headlights, dash,etc? Electricity is not my best skill set, just learning to use multimeter, could use some direction from those that wrangle these rangers. Appreciate any input.
