Dash bezel swap from a 89-92 to a 93/94
Johnnyqm
Washington
Would a wood dash bezel from a first generation facelight (89-92) fit in a 93/94? I like the wood/pinstripe option of the pre 93 dashes. The interior of the 93/94 is extremely similar to the 89-92 but I know they changed the whole body of the 93/94 so not sure if it would fit.
Bird76Mojo
1,262
IL
First generation Rangers are 1982 to 1988.
Johnnyqm
Washington
I thought the 88 revision was body and interior and not considered a generational shift until 93. Might be wrong.
snoranger
Forum Stuff Member
ASE Certified Tech
12,204
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Around here, we consider GenI 83-88, GenII 89-92, Gen III 93-97.
Yes, the bezel will fit. You’ll find some slight differences...
Under the headlight switch, some have a pocket, some have a block off plate, some are molded with “steps for switches.
Depending on the year and model, some radios mount in the dash, some mount to the bezel.
19Walt93
3,897
Canaan,NH
351
3"
235/55R16
I put a 92 bezel in my 93, I had to block the opening below the headlight switch and rework the radio opening. The 92 radio slot is a little too narrow and too tall. It wasn't a big deal.
