A 2.3 4wd ranger..lol, with a turbo that would be fun. I grew up with all engine, work with what you have..all the gear heads I have known here and all thru southern California. Knew and meet a lot of famous engine and car builders, even those that did in thier garage. Most 4wd rangers came with the 4.0, small percentage of them had the 2.3 and 3.0. Never been a fan of the 2.9. I have a 3.0 in my 94, bought him new in 94, he now has 631,777 miles. I had my original 3.0 rebuilt in 2002 at 300,000 miles. Then in 2017 at 560,000 miles i bought a good used long block from my friends yard and took it back to the same engine builder for a more thorough build. Block is .030, stonger pistos, had work done on the cam and crank shafts, 3 angle valve job on the heads, upper and lower intake manifolds, exhaust manifolds port and polished to match all that was being done. With a 5spd, 410 gears and posi rear end..a Flowmaster 44 running 2.5 piping..my ole friend does extremely good. I bought alot of Motorcraft parts for this build, lifters, oil pump, water pump, timing chain and gears, etc.
Any engine not maintained will be shut, and not go without many issues, have seen it all.
Appreciate your sayings about mine. Green has always been a favorite color of mine. Had it repainted in 99, keep care of it. Don't let Ron d catch you saying that about red..his favorite color..lol..
Those radius arms were custom built for my ranger back in 2001..he also built custom traction bars similar to a 4 link setup that prerunners use in desert racing, this was also done in 2001. He has a fab shop that he built off road suspensions, he raced in the Baja 500, 1000 races all the time. I will get a closer picture of those and the traction bbars soon.
