Dana 35 TTB Wheel O-ring size and Warn O-ring size
BMRanger
Halifax NS
Hello,
I recently needed to change my wheel bearings and seals on my 1997 Dana 35 TTB.
In the Tech section I couldn't find info on the exact sizes of the o-rings needed for the Wheel to Rotor area or the o-ring in the Warn manual locking hub. I found the sizes in the forum section.
Is there a place in the Tech section you could put these measurements and pictures for others to find?
Wheel to Rotor O-ring = 3-1/2 Inside Diameter X 3-11/16 Outside Diameter
Warn manual locking hub O-ring = 5/8 Inside Diameter X 7/8 Outside Diameter
Bought from a hydraulics repair shop:
80 cents CDN each for Wheel to Rotor O-ring
15 cents CDN each for Warn manual locking hub O-ring
These O-rings are rated for 250 C / 482 F and they're working great for me. Just replace if you see deterioration.
Thank you very much for this great forum and awesome tech section!!
Billy
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
lil_Blue_Ford
6,189
Butler, PA, USSA
4.9L
Thanks for the size information, I was thinking about this the other day. I just went looking for O-rings and found that I could get the hub to rotor one in either a standard round, a square, or an X shape. To me a square or X shape seems like it might make a little better seal than a round one, especially for off-road use... anyone else care to share some thoughts?
The only possible problem I see with the square one is it is only available in Buna-N which is oil resistant but only good for temps up to 212 F. Not sure exactly how hot that gets there. The X shape is available in Buna-N or Viton which is good to 400 F but costs around $2 per ring.
BMRanger
Halifax NS
Your Welcome!
I don't know how hot the inside of the rotor gets. From what I've read online the outer part of the rotor can get above 500 F when braking. So I just bought o-rings that had the highest rating for a good price.
kryptonitecb
19
Fort Worth, TX
I've always used RTV cause I didn't know where to find o-rings that size. Thanks for the info.
Sent from the road while ignoring traffic
BMRanger
Halifax NS
You're welcome! :icon_thumby:
lil_Blue_Ford
6,189
Butler, PA, USSA
4.9L
I ordered mine from http://www.mcmastercarr.com Of course, you have to buy like a 5-pack or 10-pack or something like that. But with all the trucks I have around here, I wasn't worried about that.
aikan50
civic
honda
I like your good work.
