Dana 35 Sway bar disconnect
Mechrick
68
Las Vegas
I made this up over the weekend and thought I'd share. The over the axle exhaust for the V8 interfered with the rear sway bar so I removed it. From prior experience, this causes the body to pitch violently left and right when off road because the body follows the front axle. I wanted a front bar for the on road stuff, so I machined and welded up a disconnect for the driver's side.
The pin and hairpin clip came from Tractor Supply. It's 1/2" and had to be machined down to approximately .480" to fit the metal sleeve of the link. The holes in the axle bracket were significantly larger than 1/2", requiring bushings to be welded to the bracket. They must fit snug or the pin will make noise.
53509
53510
53511
sgtsandman
Aircraft Fuel Tank Diver
12,707
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
That might work well for my rear sway bar. The SLA front suspension is set up differently. I need still need to mull over the best solution for it. Thanks for the tip.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
SLA sway bar quick disconnect...
53543
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
SLA sway bar quick disconnect "add on kit" for rust belt Rangers...
53544
Mechrick
68
Las Vegas
-At the foot of the trail: "Ra-ta-ta-ta-whuuurrrp!"
"What's that noise?"
"That's Uncle Gump disconnecting his sway bar."
"What was that?"
"That's Rick dropping and losing his hairpin clip in the snow." :D
scotts90ranger
4,420
Dayton Oregon
2.3 Turbo
I like the idea of disconnects, but when I did the D35 swap I just ditched the sway bar, was going to put it back in but I don't mind the body roll, apparently my front springs aren't all that soft...
sgtsandman
12,707
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
