Dana 28 Ford 7.5 to Dana 35 Ford 8.8
Ev 1988
Potosi Mo
2.9L 177CID V6 A4LD Trans BW 1350 T Case
What changes do I need for a Dana 35 Ford 8.8 in a 1987 Ford Ranger?
racer1044
Marquette, MI
http://www.therangerstation.com/tech_library/D28_D35_swap.html
You may have to shorten the front drive shaft. I installed the 6 inch lift when I swapped mine so I didnt need to shorten the shaft.
As far as the rear if its a ranger 8.8 its bolt in swap other then the flange on the dif. You will have to swap the one off your old axle or run a conversion joint. Or you can do what i did and use the drive shaft of the newer truck and mate it with you stock one.
85_Ranger4x4
17,931
SW Iowa
It only bolts in after you weld on spring perches and shock brackets.
4.0B2
151
Walls, MS
4.0 v6
he said if you use a RANGER 8.8, which is already SOA...
explorer 8.8's need the perches flipped and shock tabs welded on to bolt in a ranger or b2.
Ev 1988
Potosi Mo
Oh okay Thanks guys I will HOPEFULLY Be doing this soon after I get my transmission,wiring harness, and title fixed to be street legal
87mudslut
Firefighter
EMT / Paramedic
not to threadjack here but i have a 7.5 in my 87 as well and i want to swap an 8.8, anyone have a part number for the conversion u-joint? im having trouble figuring out my u-joint now and the size i need for the 8.8
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
EDIT: The link I posted didn't say what I thought....
I believe it's a 1330-1310 joint though.
87mudslut
Firefighter
EMT / Paramedic
sorry im on my phone, shane96, your post is showing up blank
