Dana 28 Ford 7.5 to Dana 35 Ford 8.8
Ev 1988
Potosi Mo
2.9L 177CID V6 A4LD Trans BW 1350 T Case
What changes do I need for a Dana 35 Ford 8.8 in a 1987 Ford Ranger?
racer1044
Marquette, MI
2.9
http://www.therangerstation.com/tech_library/D28_D35_swap.html
You may have to shorten the front drive shaft. I installed the 6 inch lift when I swapped mine so I didnt need to shorten the shaft.
As far as the rear if its a ranger 8.8 its bolt in swap other then the flange on the dif. You will have to swap the one off your old axle or run a conversion joint. Or you can do what i did and use the drive shaft of the newer truck and mate it with you stock one.
17,827
SW Iowa
It only bolts in after you weld on spring perches and shock brackets.
4.0B2
151
Walls, MS
4.0 v6
he said if you use a RANGER 8.8, which is already SOA...
explorer 8.8's need the perches flipped and shock tabs welded on to bolt in a ranger or b2.
Ev 1988
Potosi Mo
Oh okay Thanks guys I will HOPEFULLY Be doing this soon after I get my transmission,wiring harness, and title fixed to be street legal
87mudslut
Firefighter
EMT / Paramedic
not to threadjack here but i have a 7.5 in my 87 as well and i want to swap an 8.8, anyone have a part number for the conversion u-joint? im having trouble figuring out my u-joint now and the size i need for the 8.8
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
EDIT: The link I posted didn't say what I thought....
I believe it's a 1330-1310 joint though.
87mudslut
Firefighter
EMT / Paramedic
sorry im on my phone, shane96, your post is showing up blank
