d44 knuckles on d35
rickcdewitt
5
nor-cal
4-0 swap
homemade?
thats pretty good work is it homemade?
PARKINGLOT
St. Thomas, ON
Jeep
5.2
That's too bad you think that way. I know it's been done by an Icelandic. I remember reading about it years ago. Right here on TRS
what I mean is, it seem somewhat poorly worded...
"Find a buddy with a lathe or a brake machine to turn the rotor the smaller diameter.
You then assemble the hub using D35 brake pads (91 Explorer)
You will gain the hub and bearing spacing, but you loose the Brake upgrade.
Clearances do not seem to be a problem, but were the caliper will sit in the mount I do not know."
I understand..
"Find a buddy with a lathe or a brake machine to turn the rotor the smaller diameter." - duh. Machine down the diameter of the rotors...
"You then assemble the hub using D35 brake pads (91 Explorer)" again...simple...use 1G expo pads...
"You will gain the hub and bearing spacing, but you loose the Brake upgrade." you don't use the D44 knuckle, so you don't get bigger brakes...
but...
"Clearances do not seem to be a problem, but were the caliper will sit in the mount I do not know."
What exactly did he mean by that? is the rotor pushed farther out on spindle or something?
CopyKat
8
Manitoba, Coldest place in Canada
but...
The caliper is a floating design so if there is a variation of 1/4" or so where the caliper sits should be managable.
The only problem I could see is the size of the hat on the rotor may be very close to the caliper itself. A bit of fine grinding work and it should all fit snug.
daves302gt
Connecticut
NICE skidplate...i'll have to fasion one up for myself, or pick one of those up, Who makes that?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
He makes that. Very well built, takes a pounding and doesn't even flinch. I've got one too.
