sickwilly
- Mar 31, 2017
- 17
- ranger xlt
- Engine Size
- 3.0
I have a rear pinion seal that’s been leaking for a while now and I have some free time and I need to fix this sucker. Ive been topping it off every 6 months or so and it never takes more than few ounces but lately its started slinging oil so it needs to get done. The vent tube was stopped up, im assuming this caused the leak. AFAIK, the bearings are fine so my intention is to just replace the seal. I just want to ask a few questions before I start unbolting stuff and get hung up on some small thing. I’d rather not have to make 6 trips to town or have to order something once i have it apart. It’s the little things that always hang ya up.
OK, the plan is mark the flanges, pinion, and nut ; replace seal and put it all back just like it was. Im not planning to replace the crush washer or nut.
- How hard is the pinion nut to get off. Will a a 24” breaker bar break it loose. If I bought an impact now, it would be a $50 from HD. And those may not be worth a crap. (actually if it would do the job, I would buy one. I don’t know what’s cheap about cheap impacts). The nut is 1 1/16 right? Does it have to be a deepwell? I gotta buy one.
- Pinion flange holder. Sticking a punch, screwdriver , whatever through an unused hole would work I guess. For some reason I worry about cracking the housing, IDK why. Thought about 2-3 ft piece of 1/4” flatbar with 2 holes drilled in it. Again, I don’t know how tight the nut is.
- Do I need a puller to get the flange off or can it be tapped off with a small sledgehammer. “Tapped” being the key word.
