Core support replacement.
GMCguy1221
EMT / Paramedic
McKenney, Va
Good evening gents! Trying to help my mother in law restore her 83 ford ranger 4x4 long bed dual tank. It’s a 2.3 carbed motor with a manual transmission. I see LMC sells a new core support for 85 and newer trucks. What is the reasoning why it won’t fit an 83? The 83 has some pretty substantial rust through out the core support so need to get it changed. Also the bronco II fuel tank should fit in the factory rear tank location as well correct?!?
alwaysFlOoReD
5,124
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The only thing I can think of is the light bucket pockets might be different. That could be solved by going to an 85 up front grill?
franklin2
1,768
Virginia
I did a quick search, the 1985 radiator is aluminum with plastic side tanks like my 1986 ranger. And it's cheap also. I ran into this with my 1984 Bronco II, I am assuming the 1983 you have is the same. Look at your radiator. It's brass and has the tanks top and bottom. That is the main difference, the radiator will not fit.
My 1984 radiator was leaking. I had the 1986 sitting there as a parts truck with a brand new radiator, but quickly found it would not fit. But with some modification I made the 1986 radiator fit the 1984.
If you wanted to buy the 1985 core support, and then buy a 1985 radiator to match, you might could make it work. You will need some small parts, like the rubber donuts that the radiator sits on, etc.
GMCguy1221
EMT / Paramedic
McKenney, Va
Thank you both gents! May try and fix the 83 with the mig rig but good to know! Need to throw some questions in the engine section! Thanks again
franklin2
1,768
Virginia
P.S. Something important that I forgot to mention; You may need new radiator hoses to match the later radiator.
