Conversion kit?
Would you buy one?
  • Yes
    Votes: 1 20.0%
  • No
    Votes: 2 40.0%
  • Depends on price
    Votes: 2 40.0%
  • Total voters
    5
NakedDucks
63
B’ham AL
If someone were to make a true conversion kit to turn an Electric 13-54 to a true manual shifted one, would you buy one?
I'm talking new shift rails, new front case 1/2, and a new shift arm......possibly even using some parts cannibalized from an manual shifted 13-50 to help keep costs down.
Not some contraption that bolts to the back and turns the shaft like another manufacturer made, but uses a "stock" floor shifter and boot?
I would of course follow the needed and correct channels on here to become a vendor if this idea materializes.
Edited to include a question:
Whats the most you'd pay for this kit?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I thought the 1354 came either electric or manual. If so, couldn't you just find a manual setup and steal the linkage and install on your t/case? or would that not be possible due to the module?
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The internals are different. Everything other than the gears, shafts, and forks are different between the two. Even the outer cases are drilled differently.
NakedDucks
63
B’ham AL
They did, but the manual versions are EXTREMELY hard to find, damn near impossible actually.....
franklin2
1,758
Virginia
Bronco II
I keep the electric motor and just put a on-off-on center return toggle switch on them. Works and hooks up like a electric window setup, only instead of moving the window up and down you are moving the electric shift motor back and forth. Only problem selling something like this is liability when some doe doe moves the switch when they are not supposed to. I guess you could reach down on a manual transfer case and pull the lever back at the wrong time and trash it also. But since it was your switch, they would probably come after you for it.
NakedDucks
63
B’ham AL
It would have a floor shifter like a manual 13-50 does.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The downfall is that you have to remove and disassemble the T Case to install it. That might limit many folks that won't do those repairs themselves. I'm sure there will be some interest in it though. I would consider one myself if when I do a M5OD swap in my Bronco II.
I still like the thought of having one of the old shiftsters to get me out of trouble for my truck box.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
As for what I would pay? I don't really know. Seems like it could get a bit spendy.
Junk Collector
Truck of Month
4,800
Rapid City SD
I think it's a cool idea but my suggestion would be to come up with a cable or linkage setup that actuates the shift mechanism on an electric shift t-case and simply replaces the electric motor while giving you a shift lever at the same time. IIRC Behemoth Drivetrain? or some other place made a product like that at one point but no longer do. Easy, bolt on kit that could give you a lever on the floor in a couple hours.
My opinion is that something along those lines would sell better and FAR less R&D involved. If I needed a kit like that I would be willing to spend up to about $250. I suspect a new front case half for a 1354 plus a shifter and whatever else would end up being 3-4x that much, and require t-case disassembly. If I'm a grand into a 1354, I would rather save that cost and drop it on an Atlas instead.
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I designed a prototype like that years ago. It used a 3:1 gear reduction made from gears available from Grainger and 1/2” x 4” aluminum flat stock for the t case side. I never got around to locating a cable, but I planned to use a cheap aluminum shifter from Speedway Motors.
NakedDucks
63
B’ham AL
The one from Behemoth costs around $800
franklin2
1,758
Virginia
Bronco II
I tried using a grease gun hose as a driveshaft and put a shifter in the cab. It didn't work very well. Part of the problem, even with the shiftsters knob I suspect (never had one) are the detents for each gear position are not very positive. If you had your own mechanical shifter, it would have to be carefully gated and adjusted to get the different modes.
The motors used to be available in the store for not much money. If you wanted to spend a little time, I think a electrical solution would be better than a mechanical solution. Electrical meaning more robust and simpler than the factory setup. Engineers need to justify their jobs with a lot of engineering you know. That seems to be their downfall sometimes.
NakedDucks
63
B’ham AL
I could offer build service if needed.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That might be an option too... just sell it completed. Many folks what bolt in.
I would tackle that job for myself.
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
If you can do it and make it affordable, that would be great. Personally, I try to keep things to the cheap side. I shop at the junk yard, Craigslist and Facebook Marketplace or I build what I need. Like Shran said, if it costs a thousand or more, I'd probably save up for an Atlas and have a more robust case with better gear ratios.
